15 years agoSUb block with altera
Hello dear all,
I have a question for you: how can I create a sub diagram to reuse many times in the same project, using Block diagram/Schematic File? I hope to explain in the correct way what I'dmlike to do.... Thanks in any case Matthew8 Replies
this issue sounds familiar, try searching the forum
ok the file shall be already existing... shall not it?
for any name I can try to save, It shows me the same alert:
'Can't open read-only file C:/..../Test.bsf' :( - Altera_Forum
yes.
Are you sure you're not trying to overwrite another file with the same name? - Altera_Forum
you need to create the symbol file. you cannot save a .bdf as a .bsf.
I have tried to save the file .bsf, as Test.bsf, but it appear an alert like:
'Can't open read-only file C:/..../Test.bsf'. what does it mean? I have Student's Edition. :) - Altera_Forum
in the menus:
file -> create/update -> create symbol file for current file. You can do this with HDL or a bdf.
