15 years agoStruggling with boot from initialized onchip RAM
Greetings fellow Alterians! I am using Quartus II 9.1 SP2, Cyclone III (16K) and EPCS16. My development board works fine and I can download and run software on my NIOS II via USB Blaster with ...
15 years ago1. Point your Reset Address at your onchip memory.
2. Compile your code. 3. If it's too large, optimize it. - Use alt_io stuff, small C Library, reduced device drivers, etc. 4. Create your memory HEX file. - Know that you "may" have to manually move it into the root of your QII project. 5. Recompile your QII design. - If you're lucky and all you've changed is the HEX memory initialization file, this step should be quick. 6. Program your FPGA. 7. Open a nios2-terminal and you should see proper output. Regards, slacker
