BJona
7 years agoStratix10MX, triple speed ethernet LVDS IO
Hi, I'm planning to use several triple speed ethernet Mac IPs but as far as i could see, you can't use Tile transceivers to do that. So i tried to compile my design with TSE (lvds io with integrated...
BJona
7 years agoHi dlim,
1) I found a limit of 14 TSE IPs. After this number, the fitter could not find a suitable scheme for pin assignements. (it seems you can drive only 1 PLL per bank, i think i read this limitation somewhere in a datasheet )
I sent you the .qar file of my early design with 15 TSE LVDS IO.
2) There is no design example provided with S10 soc kit which instanciates a TSE IP with LVDS IO. However, you can see in golden_top design (see the attached qar) that sgmii pins are linked to gxb transceivers. Those ones may be used with a 1G/10G phy design but there is no example which explicitly shows how it has been implemented.
Maybe, you can tell me more about this.
Thank you,
Have a nice day,
regards,
John
