18 years agostratix write2flash.exe & non-volitile configuration
Hi, I have a Stratix EP1S80 board which I would like to program the flash for non-volatile configuration. I am using Quartus 7.2 and can generate the .sof file for regular configuration via the pa...
18 years agoI guess, that the solution for the Stratix II DSP Board also applies to your board:
--- Quote Start --- In the Stratix II EP2S60 DSP Development Board Data Sheet, in the Non-Volatile Configuration section, the Write2Flash utility is mentioned as a tool you can use to download user configuration data into the on-board flash. The new method is to use the Nios® II Flash Programmer through the Nios II SDK Shell. ... Refer to the Nios II Flash Programmer User Guide for more detailed instructions on using the Nios II Flash Programmer. --- Quote End ---
