13 years agoStratix V full reconfiguration only works conditionally
On my Stratix V board, the ability to do a full reconfiguration of the device by asserting !nCONFIG is dependent on the state of the device. I have never seen this before, nor seen it documented. ...
13 years agoI don't have a dev kit available. I was hoping someone here that has a devkit or their own design could confirm or deny the existence of the issue, and if it does exist point to a user error causing it.
I think in the case of the kit boards that have both serial and parallel flash config options most times it will the the parallel that is getting the workout. I've filed an SR. Thanks.
