14 years agoStratix IV Tecnical Problem
Dear Sir
I have bought Stratix IV 4SGX230N from your site. We have read that this board supports SFP-HSMC card. Therefore we need to buy this card but our research needs high speed up to 10GB. My question is that can this board with SFP-HSMC card accept SFP+, XFP?. My Best Wishes Waddah13 Replies
You did not buy the kit from this site. This is a user-maintained forum.
Stratix IV GX devices do not support 10.3125Gbps transceiver rates. Stratix IV GT devices do, and Stratix V devices do. Cheers, Dave - Altera_Forum
Thank you for your replaying
Is the board (DUAL XAUI TO SFP+ HSMC BOARD) suitable with Stratix IV 4SGX230N to achieved up to 10Gbps ? Waddah - Altera_Forum
--- Quote Start --- Is the board (DUAL XAUI TO SFP+ HSMC BOARD) suitable with Stratix IV 4SGX230N to achieved up to 10Gbps ? --- Quote End --- Do you have a link to the board? XAUI is 4 x 3.125Gbps, so if the board you refer to has a PHY chip that takes in XAUI and outputs 10.3125Gbps to SFP+, then yes, it would work with the Stratix IV GX FPGA. Cheers, Dave - Altera_Forum
Yes i have the link ,but i can't send it you here .
Please give you your e.mail. - Altera_Forum
Its staring you in the face ... its my forum name :)
http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=71&no=597&partno=2
Yes, this board will do what you need. NOTE: the HSMC connector on the Stratix IV GX kit supports 8 transceivers on the connector on the left, but only 6 on the right, so you can only use one of these boards and get two SFP+ ports. You might be able to add a second board, but you would only get one more SFP+ port. Cheers, Dave - Altera_Forum
Thank you very much
How can i buy it? I need it as soon as possible - Altera_Forum
--- Quote Start --- How can i buy it? I need it as soon as possible --- Quote End --- Contact Terasic. Cheers, Dave - Altera_Forum
I want to Test Designs Using Stratix IV GX FPGA Development + Dual xaui SFP HSMC
this required (hsmc_loopback.sof) How can i find this file - Altera_Forum
--- Quote Start --- I want to Test Designs Using Stratix IV GX FPGA Development + Dual xaui SFP HSMC this required (hsmc_loopback.sof) How can i find this file --- Quote End --- From its name, hsmc_loopback, it implies loopback at the HSMC. This is not what you want for testing a XAUI/SFP+ HSMC board. Terasic likely have an example for that. I am sure there are several layers of loopback; 1) A simple loopback where data from SFP+ is received over XAUI and then sent back over the link. 2) A more complex loopback where data is received as 10GbE packets and the contents checked. You'll want to perform both sorts of checks. Cheers, Dave
