14 years agoStratix IV GX transceiver transmit simulation
I am trying to simulate (with Mentor Questa) the transmit part of a Stratix IV GX transceiver. I defined the protocol as basic and I disabled the 8b10b part. Whatever I set on the txdatain port, I get the tx signal of the transceiver toggling in the same sequence. I get a sequence is: 1111011000111101100 (that could look like a K.28.6 in 8b10b) I want to use the transmitter to generate a high speed signal without any protocol. (I don't want/need clock recovery on the receiver side). So I just want the value on txdatain to be serialized. Transceiver vhdl file is attached. Did any run a simulation successfully in such a setup? Thanks, raph Here is my mapping: Trans_inst : Trans port map ( cal_blk_clk => Clock_125, pll_inclk => Clock_125, reconfig_clk => '0', reconfig_togxb => "0000", rx_coreclk => Clock_125_bus, rx_cruclk => Clock_125_bus, rx_datain => dataline, rx_locktodata => "00", rx_locktorefclk => "11", tx_coreclk => Clock_125_bus, tx_datain => "1111111111111111111111111111111111111111", reconfig_fromgxb => open, rx_clkout => open, rx_dataout => open, tx_clkout => open, tx_dataout => dataline); PS2: I get the following message while simulation, I doubt it is related: # ** Warning: (vsim-8683) Uninitialized out port /tb/Sata_trans_inst/Sata_trans_alt4gxb_component/cal_blk0/nonusertocmu has no driver. # This port will contribute value (U) to the signal network. # ** Warning: (vsim-8684) No drivers exist on out port /tb/Sata_trans_inst/Sata_trans_alt4gxb_component/ch_clk_div0/dprioout(99 downto 94), and its initial value is not used. # Therefore, simulation behavior may occur that is not in compliance with # the VHDL standard as the initial values come from the base signal /tb/Sata_trans_inst/Sata_trans_alt4gxb_component/wire_ch_clk_div0_dprioout(99 downto 94).1 Reply
Nevermind, I added the gxb_ powerdown signal and it is ok now....
r.
