18 years agostratix III with DDR2 temination
hi my design include stratix III device with 2 ddr2 hp core. each core is facing 5 DDR2 components when 1 of the 5 is for ECC. i looked at the termination schemes in AN408 and not found my ans...
18 years agoI didn't use Stratix III yet. Rs is the serial termination, 50 ohm for SSTL class I respectively 25 ohm for SSTL class II. It can be set independantly of dynamic OCT, but I expect that both are used by default when generating a DDR2 controller by the MegaWizard. It's important to follow the instructions and also import the *.tcl files that contain these settings.
I would generally follow the termination scheme suggested in AN408 (updated revison of July 2008!). This means one external parallel termination at the RAM for CMD/ADDR and no external termination for DQ/DQS. With your rather slow 150 MHz clock, the design may also operate without external termination, but I won't recommend it. There are, by the way, also specifications regarding maximal delay skew for CLK to ADDR/CMD and DQS to DQ.
