15 years ago
Stratix-II GXB Reconfiguration simulation trouble
Hello.
I am trying to simulate GXB transceiver reconfiguration for Stratix-II IC in Modelsim-Altera.
My Quartus version is 9.1sp1.
I am creating transceiver block that can be reconfigured in 2 states:
1) STM-16(OC-48)
2) Basiс mode
I am creating this transceiver according to Stratix-IIGX handbook, volume II section I.
When I simulate the GXB transceiver with reconfiguration possibility, I can see the following waveforms (see picture).
After the reset sequence, when tx_digitalreset = 0 (inactive), transmitted signal became consisting z-states (pink lines in GX_TX signal).
If I reconfigure the transceiver (uploading .mif file into it), the behavior is the same: after the reset sequence, when tx_digitalreset = 0 (inactive), transmitted signal became consisting z-states (pink lines in GX_TX signal).
When tx_digitalreset = 1 (active), there is no z-states in the output signal.
Did anybody try to simulate reconfiguration in Stratix-IIG?
What can lead to z-states in the output of the transmitter?
What is the problem and how it could be solved.
Thank you in advance.
    The problem is solved.
    My TX_Data[15:8] were not connected to the proper tx_datainfull input of the GXB, so Modelsim used "z-state" as a values of thу MSB of the transmitted data and it transmitted z-state to the output high-speed line.
    Nobody tryed to reconfigure Stratix-II transceivers?
    Or transceivers of any other Stratix/Cyclone/Arria?
