18 years agoStratix Ii Gx And Alt2gxb Ip
Hello, I'am new on FPGA and I have some questions. I try to implement the alt2gxb ip on a stratix II gx. here all is ok. In my design I receive datas from an optical fiber with t...
18 years agoI dont know your receiver device, but if it has RXN and RXP signals, I would regard this as differential output that could be connected to GXB differential input (assuming the signal level, termination etc. are suitable). In the HDL design, this signal should be represented by a single rx_datain input port, that could be connected to GXB transceiver instance.
