18 years agostrange SCFIFO behaviour
Hi all, I am experiencing some problems with a "supposed to be" simple SCFIFO. I've instatiated it via the megafunction, but I have 2 problems, one of these driving me a little bit crazy: 1) ...
18 years agoHi Rysc,
thanks so much for your answer: I ended using your solution just few minutes before reading your post: I was trying almost everything to make my fifo work, so I tried to "split" the if..then and now it's working (I had the same problem on the fifowrite, now solved). Anyway, I must admit that mine were just tryouts, your solution with an explanation is surely better! thanks again, all the best, C. PS point 1) of my first post - the warning - is still there.. until it seems to work I don't care of it, but I'm curious why I have this warning!
