15 years ago
Statemachine error
Hi I think i have a statemachine that makes a ibutton interface top communicating.
I think it is in the code below. Could some one have a look. On thing I found that DQ_IN is in input that is not clocked but is used for state selection.
I guess this could put the statemachine in an unconditioned state (metainstability) But i'm having a hard time proving this.
I can't find it in practice nor any documentation about this.
This is the code:
OneWireReset_machine: process(clk, MR)
-- machine variables
variable count: INTEGER range 0 to 1000;
variable smCnt: INTEGER range 0 to 32;
begin
if (MR = '1') then --synchronous reset
count:=0;
OneWireReset <= Idle;
pdr <= '1';
elsif (clk'event and clk = '1') then
if (clk_en = '1') then
case OneWireReset is
when Idle =>
count := 0;
if owr = '0' then
elsif owr = '1' then
OneWireReset <= Reset_Low;
end if;
when Reset_Low =>
count := count +1;
pdr <= '1';
if count = 500 then
OneWireReset <= PD_Wait;
end if;
when PD_Wait =>
count := count +1;
if count = 515 then
OneWireReset <= PD_Edge;
end if;
when PD_Edge =>
count := count +1;
if DQ_in = '0' then -- Adapted for Granada situation
OneWireReset <= PD_Sample;
smCnt := 0;
elsif count = 560 then
smCnt := 0;
end if;
when PD_Sample =>
count := count +1;
smCnt := smCnt +1;
if smCnt = 30 then
pdr <= DQ_in; -- presence detect register
OneWireReset <= Reset_High;
end if;
when Reset_High =>
count := count +1;
if count = 1000 then
OneWireReset <= Reset_End;
end if;
when Reset_End =>
when others =>
null;
end case;
end if;
end if;
end process;
    unsynchronise it - if the problem comes back, thats your problem. You only made a small change.
    Using unsynchronised signals in synchronised logic has a habit of causing these problems.
    Hi Thanx for the answer. That is what I did but I need solid proof that that was the issue.
    The error in the machine can't be introduced on command and happens random. Sometimes once each day and on other machines once in a week.
