13 years agoState Machines - advantages and disadvantages
Hi Guys, I would like to ask the next question: As a rule, I buidling the state machine when my inputs and outputs are places in the same state machine. But in Mealy/Moore state machine there...
13 years ago --- Quote Start --- Hi, while all types of coding (assuming correct code) should result in same behaviour, there might be some difference in resource usage. ... ... Has anyone tried to implement a more or less small FSM in these two styles to compare the resource usage in e.g. Cyclone devices which are more register than LUT based...? --- Quote End --- Ok, you might be right. But I never thought about it and used the more readable style all the time. But you are right, it would be interesting, if there are differences in resource usage. Could anyone make a declaration about this topic? Greets sim
