18 years agostate machine view problem, need help
I am new to this forum. Recently I started learning Altera. I was trying to compile combinational bench mark file s27.v and during compilation I got a warning : "dff" is an internal primitive and got...
18 years agoI also tried with another bench mark circuit s298(traffic light circuit)
//# 3 inputs //# 6 outputs //# 14 D-type flipflops //# 44 inverters //# 75 gates (31 ANDs + 9 NANDs + 16 ORs + 19 NORs) module dff1 (clk,Q,D); input clk,D; output Q; reg Q; always @(posedge clk) begin Q<=D; end endmodule module s298(GND,VDD,CK,G0,G1,G117,G118,G132,G133,G2,G66,G67); input GND,VDD,CK,G0,G1,G2; output G117,G132,G66,G118,G133,G67; wire G10,G29,G11,G30,G12,G34,G13,G39,G14,G44,G15,G56,G16,G86,G17,G92,G18,G98, G19,G102,G20,G107,G21,G113,G22,G119,G23,G125,G28,G130,G38,G40,G45,G46,G50, G51,G54,G55,G59,G60,G64,II155,II158,G76,G82,G87,G91,G93,G96,G99,G103,G108, G112,G114,II210,II213,G120,G124,G121,II221,G126,G131,G127,II229,II232, II235,II238,G26,G27,G31,G32,G33,G35,G36,G37,G42,G41,G48,G47,G49,G52,G57, G61,G58,G65,G62,G63,G74,G75,G88,G89,G90,G94,G95,G100,G105,G104,G110,G109, G111,G115,G122,G123,G128,G129,G24,G25,G68,G69,G70,G71,G72,G73,G77,G78,G79, G80,G81,G83,G84,G85,G43,G97,G101,G106,G116,G53; dff1 DFF_0(CK,G10,G29); dff1 DFF_1(CK,G11,G30); dff1 DFF_2(CK,G12,G34); dff1 DFF_3(CK,G13,G39); dff1 DFF_4(CK,G14,G44); dff1 DFF_5(CK,G15,G56); dff1 DFF_6(CK,G16,G86); dff1 DFF_7(CK,G17,G92); dff1 DFF_8(CK,G18,G98); dff1 DFF_9(CK,G19,G102); dff1 DFF_10(CK,G20,G107); dff1 DFF_11(CK,G21,G113); dff1 DFF_12(CK,G22,G119); dff1 DFF_13(CK,G23,G125); not NOT_0(G28,G130); not NOT_1(G38,G10); not NOT_2(G40,G13); not NOT_3(G45,G12); not NOT_4(G46,G11); not NOT_5(G50,G14); not NOT_6(G51,G23); not NOT_7(G54,G11); not NOT_8(G55,G13); not NOT_9(G59,G12); not NOT_10(G60,G22); not NOT_11(G64,G15); not NOT_12(II155,G16); not NOT_13(G66,II155); not NOT_14(II158,G17); not NOT_15(G67,II158); not NOT_16(G76,G10); not NOT_17(G82,G11); not NOT_18(G87,G16); not NOT_19(G91,G12); not NOT_20(G93,G17); not NOT_21(G96,G14); not NOT_22(G99,G18); not NOT_23(G103,G13); not NOT_24(G108,G112); not NOT_25(G114,G21); not NOT_26(II210,G18); not NOT_27(G117,II210); not NOT_28(II213,G19); not NOT_29(G118,II213); not NOT_30(G120,G124); not NOT_31(G121,G22); not NOT_32(II221,G2); not NOT_33(G124,II221); not NOT_34(G126,G131); not NOT_35(G127,G23); not NOT_36(II229,G0); not NOT_37(G130,II229); not NOT_38(II232,G1); not NOT_39(G131,II232); not NOT_40(II235,G20); not NOT_41(G132,II235); not NOT_42(II238,G21); not NOT_43(G133,II238); and AND2_0(G26,G28,G50); and AND2_1(G27,G51,G28); and AND3_0(G31,G10,G45,G13); and AND2_2(G32,G10,G11); and AND2_3(G33,G38,G46); and AND3_1(G35,G10,G11,G12); and AND2_4(G36,G38,G45); and AND2_5(G37,G46,G45); and AND2_6(G42,G40,G41); and AND4_0(G48,G45,G46,G10,G47); and AND3_2(G49,G50,G51,G52); and AND4_1(G57,G59,G11,G60,G61); and AND2_7(G58,G64,G65); and AND4_2(G62,G59,G11,G60,G61); and AND2_8(G63,G64,G65); and AND3_3(G74,G12,G14,G19); and AND3_4(G75,G82,G91,G14); and AND2_9(G88,G14,G87); and AND2_10(G89,G103,G96); and AND2_11(G90,G91,G103); and AND2_12(G94,G93,G13); and AND2_13(G95,G96,G13); and AND3_5(G100,G99,G14,G12); and AND3_6(G105,G103,G108,G104); and AND2_14(G110,G108,G109); and AND2_15(G111,G10,G112); and AND2_16(G115,G114,G14); and AND2_17(G122,G120,G121); and AND2_18(G123,G124,G22); and AND2_19(G128,G126,G127); and AND2_20(G129,G131,G23); or OR4_0(G24,G38,G46,G45,G40); or OR3_0(G25,G38,G11,G12); or OR4_1(G68,G11,G12,G13,G96); or OR2_0(G69,G103,G18); or OR2_1(G70,G103,G14); or OR3_1(G71,G82,G12,G13); or OR2_2(G72,G91,G20); or OR2_3(G73,G103,G20); or OR4_2(G77,G112,G103,G96,G19); or OR2_4(G78,G108,G76); or OR2_5(G79,G103,G14); or OR2_6(G80,G11,G14); or OR2_7(G81,G12,G13); or OR4_3(G83,G11,G12,G13,G96); or OR3_2(G84,G82,G91,G14); or OR3_3(G85,G91,G96,G17); nand NAND3_0(G41,G12,G11,G10); nand NAND3_1(G43,G24,G25,G28); nand NAND4_0(G52,G13,G45,G46,G10); nand NAND4_1(G65,G59,G54,G22,G61); nand NAND4_2(G97,G83,G84,G85,G108); nand NAND4_3(G101,G68,G69,G70,G108); nand NAND2_0(G106,G77,G78); nand NAND4_4(G109,G71,G72,G73,G14); nand NAND4_5(G116,G79,G80,G81,G108); nor NOR2_0(G29,G10,G130); nor NOR4_0(G30,G31,G32,G33,G130); nor NOR4_1(G34,G35,G36,G37,G130); nor NOR2_1(G39,G42,G43); nor NOR3_0(G44,G48,G49,G53); nor NOR2_2(G47,G50,G40); nor NOR2_3(G53,G26,G27); nor NOR3_1(G56,G57,G58,G130); nor NOR2_4(G61,G14,G55); nor NOR4_2(G86,G88,G89,G90,G112); nor NOR3_2(G92,G94,G95,G97); nor NOR2_5(G98,G100,G101); nor NOR2_6(G102,G105,G106); nor NOR2_7(G104,G74,G75); nor NOR2_8(G107,G110,G111); nor NOR2_9(G112,G62,G63); nor NOR2_10(G113,G115,G116); nor NOR3_3(G119,G122,G123,G130); nor NOR3_4(G125,G128,G129,G130); endmodule With the modification of "dff1" in this code, it's compiling properly but same problem. I am able to see RTL viewer but not state machine viewer. Please advise me...
