18 years agostate machine view problem, need help
I am new to this forum. Recently I started learning Altera. I was trying to compile combinational bench mark file s27.v and during compilation I got a warning : "dff" is an internal primitive and got...
18 years agoYou should post the said benchmark for better understanding. Basically there are some prerequisites to let Quartus integrated synthesis tool recognize a state machine, that are discussed in the Quartus Handbook in chapter 6 recommended hdl coding styles under general coding guidelines, state machines. The code - if syntactically correct - should work also without recognizing a state machine.
