19 years agoST Serial Flash Memory vs EPCS
hello, gals and guys. i am preparing for a FPGA board design. As to the configuration chip, i want to use the ST serial flash memory M25P128 or M25P64 to substitute the EPCS128 and EPCS64. While i am...
19 years agofootprint and pinout are the same. so you can try both. it is rumoured that alteras serial flashes are made by st. you've to add the st-flash as a new device using the quartus programmer ("new device"). maybe the jtag id is different!?
