17 years agoSOPC/Quartus II "pass through component" problem
Hi Everybody, I have Quartus 9.0 running on Cyclone III Board with Bitec's HSMC DVI daughterboard on it. I have Clocked Video Input (1080p60 DVI input) and Clocked Video Output (1080p60 DVI ...
17 years agoAnother problem,
So, the project runs with CVI->frame buffer->CVO but when I add my new pass through component, all I see is a white screen. Before I changed the auto-generated code, I was seeing a black screen, and after changes I made, I am seeing white screen now. So it is an improvement but still, I am not able to see the actual display as my output. The code I changed for my custom component is as followed. Am I forgetting something ? I obviously do :) // new_component_2.v // This file was auto-generated as a prototype implementation of a module // created in component editor. It ties off all outputs to ground and // ignores all inputs. It needs to be edited to make it do something // useful. // // This file will not be automatically regenerated. You should check it in // to your version control system if you want to keep it. module new_component_2 ( input wire clock, // clock.clk input wire reset, // .reset input wire ready, // avalon_streaming_source.ready output wire valid, // .valid output wire [23:0] data, // .data output wire startofpacket, // .startofpacket output wire endofpacket, // .endofpacket output wire ready1, // avalon_streaming_sink.ready input wire valid1, // .valid input wire [23:0] data1, // .data input wire startofpacket1, // .startofpacket input wire new_signal_11 // .endofpacket ); //assign valid = 1'b0; assign valid = valid1; //assign startofpacket = 1'b0; assign startofpacket = startofpacket1; //assign endofpacket = 1'b0; assign endofpacket = new_signal_11; //assign ready1 = 1'b0; assign ready1 = ready; //assign data = 24'b000000000000000000000000; assign data = data1; // TODO: Auto-generated HDL template endmodule And my SOPC design pic is enclosed.
