17 years agoSOPC/Quartus II "pass through component" problem
Hi Everybody, I have Quartus 9.0 running on Cyclone III Board with Bitec's HSMC DVI daughterboard on it. I have Clocked Video Input (1080p60 DVI input) and Clocked Video Output (1080p60 DVI ...
17 years ago --- Quote Start --- I think you need the frame buffer because of the synchronization problems you might have with DVI throughout , am I correct ? --- Quote End --- yes, correct. as jakobjones mentioned, you will need to add framebuffer before clocked video output. so, if you want to put your dummy passthrough component , then you can place it between clocked video input and framebuffer. you will need to refer the verilog hdl books for the basics, i think. just giving a simple example of a pass through component for you to start with. module dummy_module(clk, reset, data_in, data_out); input [7:0]data_in; input clk; input reset; output [7:0] data_out; assign data_out = data_in; endmodule here add the necessary signals like you mentioned (clk, reset, data, valid , ready. etc). you can start with simple modules to get better understanding about the data types and signal connection and stuff. good luck!
