13 years agoSOPC warning- Quartus 12.0-
In my sopc builder I don't use any custom component. But it shows the following error msg. cpu_0:Custom Instruction components can be edited through the component editor Is this a problem...
13 years agoHi, you are new to NIOS II, aren't you ?
SOPC will be unsupported. It is replaced with QSYS, quite similar. Both get still bugs (path, script, missing...) Do you work with an Altera developpment board ? DE2-2C35 ;-) ? --- Quote Start --- cpu_0:Custom Instruction components can be edited through the component editor --- Quote End --- could you post you SOPC (image or file) ? --- Quote Start --- (says Leaving target processor paused) --- Quote End --- After programming flash, it is normal. You can "start" the processor by : resetting your board, then the proceessor will boot, usually, at the boot sector in a Flash memory entering "nios2-terminal -g" something like that in a Nios Shell.
