15 years agoSOPC New Component Control 7 Segment LED
Hi every body, I'm a newbie in SoPC. I use DE2. I want to create a new component connect to Avalon Switch Fabric (ASF). This component uses to control 7 segment LED. ASF will create write...
15 years agohello.
have you check this source somehow? you can check it in modelsim( you can download it from Altera web site) or QuartusII can compile it. I have found some errors. 1.write_data it can't be a register. it is an input-bus. 2.syntax the line "else HEX7 = 7'b1000000" you need semicolon. this is just a syntax error. 3. logical error. you don't have output. a module which has no output doesn't make sense. those are my advice as far as I found.
