15 years agoSOPC Cyclone 3 starter board
Hi all,
I have this attached design when i run nios2-download zImage : --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK Downloaded 1424KB in 26.6s (53.5KB/s) Verified OK Leaving target processor paused --- Quote End --- when i run nios2-terminal --- Quote Start --- nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB 5-1.2]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) --- Quote End --- After nothing appears on my screen !!!! thanks for help2 Replies
Thank you very much
It s ok now :) - Altera_Forum
you need to add the -g option to nios2-download to start the processor after the image upload
