14 years agoSOPC Builder and nios ii help
hi... i am new to altera,currently am doing my final year project with altera cyclone ii...i dont know using SOPC builder and nios ii...kindly help me with that...thanks...
14 years agothanks for the reply...
i tried running the code but am getting the error as follows make -s all includes Compiling LCD.c... Compiling Test.c... Compiling toplevel.c... ../toplevel.c: In function `ethernet_interrupts': ../toplevel.c:81: error: `DATA_IN_BASE' undeclared (first use in this function) ../toplevel.c:81: error: (Each undeclared identifier is reported only once ../toplevel.c:81: error: for each function it appears in.) ../toplevel.c:83: error: `DATA_TYPE_BASE' undeclared (first use in this function) ../toplevel.c:85: error: `DATA_ACK_BASE' undeclared (first use in this function) ../toplevel.c: In function `main': ../toplevel.c:206: error: `CPU_IP_READY_BASE' undeclared (first use in this function) ../toplevel.c:209: error: `CPU_IP_MAC_H_BASE' undeclared (first use in this function) ../toplevel.c:210: error: `CPU_IP_MAC_L_BASE' undeclared (first use in this function) ../toplevel.c:226: error: `CPU_IP_LENGTH_BASE' undeclared (first use in this function) ../toplevel.c:228: error: `CPU_IP_INDEX_BASE' undeclared (first use in this function) ../toplevel.c:230: error: `CPU_IP_DATA_BASE' undeclared (first use in this function) ../toplevel.c:237: error: `CPU_IP_DONE_BASE' undeclared (first use in this function) ../toplevel.c:245: error: `CPU_ARP_READY_BASE' undeclared (first use in this function) ../toplevel.c:248: error: `CPU_ARP_MAC_H_BASE' undeclared (first use in this function) ../toplevel.c:249: error: `CPU_ARP_MAC_L_BASE' undeclared (first use in this function) ../toplevel.c:266: error: `CPU_ARP_INDEX_BASE' undeclared (first use in this function) ../toplevel.c:268: error: `CPU_ARP_DATA_BASE' undeclared (first use in this function) ../toplevel.c:276: error: `CPU_ARP_DONE_BASE' undeclared (first use in this function) ../toplevel.c:170: warning: unused variable `TXT_INIT' make: *** [obj/toplevel.o] Error 1 Build completed in 39.094 seconds
