16 years agoSOPC and beginbursttransfer
I am creating a custom Avalon MM Master that will need to speak to a HPCII DDR2 controller. Rather than generating the core in the SOPC tool, we are generating it using the Megawizard in Quartus. ...
16 years agoHistorically that signal was used by the memory controller (not sure if it still does). That said you don't need to worry about it since it's a signal generated by the fabric and not the master. The fabric will know when a burst is starting drive it to the memory controller. So following the Avalon-MM spec you only need to include the subset of signals needed by your master and you let the fabric take care of the rest.
