15 years agosome procblem about delay
I have a 50M data stream, But I need it delay 32us matching with other signals. How can I do it?
Thank you very much3 Replies
--- Quote Start --- Thank you very much! I think that is a way, however it require so much resources. --- Quote End --- Yes. if its too many resources either: 1. redesign your system so you dont need such a large delay 2. get a bigger chip 3. Use an external ram. - Altera_Forum
At 50MHz, you need it to delay it by 1600 clock cycles, using a large shift register.
Depending on the width of your data stream, that may require quite a bit of resources. I suggest you use the ALTSHIFT_TAPS function, so the shift register is implemented in RAM.
