15 years agosome problem about FIFO
Hello everyone! I created a FIFO using megaWizard.I used it to store the data from the ADC. When I used the 1M FIFO CLK,it works properly. But I used the 2M FIFO CLK ,it don't work properly.I ...
15 years agoAre you sampling the FIFO empty, full, and empty signals? If not I recommend you do just in case your FIFO is over/underflowing at the higher clock rate.
