13 years agoSome problem about CPLD EPM570
Hello, I have some problems about EPM570. What's the GCLK maximum value that could be accepted? I searched datasheet and found it can input higher than 100 MHz. But I input a 100 MHz XTAL and C...
13 years agoDon't know what you mean with "detect I/O pin"?
Besides correct waveform of the clock oscillator signal (voltage level, rise/fall times, clean edges), timing analysis should verify that the design can run at 100 MHz.
