17 years agoSome glitches in the simualtion waveforms
Hi, Experts, I met a problem in my VHDL code. My algorithm is to cut in the deadtime in the incoming PWM signals and output them. I have 6 incoming PWM signals to switch 6 IGBTs. So, these 6 p...
17 years agoIn deadtime_1 you have
first_pair: process (clkin, pwm_top1_in) The only signals in the process sensitivity list should be the clock and asynchronous control signals like a reset. It looks like you wanted to use pwm_top1_in as a synchronous input to the register. The synchronous inputs should not be in the sensitivity list.
