18 years agoSolution for a high-performance "translation" board
Hello, I'm in the very initial stages of design of a card that should do the following: * Receive data from 4-5 optical links. The data comes at ~200MBit/s per link - on a single data line...
18 years agoIf you can find an external IC that will do your CDR, that is actually the best way to go for your design. It will present you with your 100 or 200 MHz clock which you can drive into any FPGA. That way you wouldn't need a transceiver part and you can save some money.
Jake
