13 years agosof2flash issue in 12.1sp1
Hi all Now I'm involved porting some old NIOS2 based designs (built with the 10.0 version of Quartus) from the SOPC builder tool to the Qsys tool (in version 12.1sp1 of Quartus). When usin...
13 years agoIn case it helps shed any light on the issue - I had an issue with sof2flash not working as I moved to another PC that only had the webpack 9.1 tools installed. When I ran sof2flash --help it did not show a --pfl option indicating it was not the full version. When I ran in a nios II 12.0sp2 command window it worked fine. I would check it is calling the correct version.
