15 years agoSoC component
Hi every body, please i need a confirmation before i start to create my SoC. In attached picture wich represent the component that i need in my SoC. I don't know really, in each SoC it is ...
15 years agoOh okay, are you using the Sopc component directly as a top level file? In that case Sopc Builder may have created a clock output, and the pin planner wants you to place it somewhere. As you don't need it, you can simply connect it to an unused I/O (such as one of the pins on the expansion ports) or an SMA output.
If you instantiate the Sopc component inside your top level file, you can simply leave the clock output unconnected.
