mmeyers
5 years agoslvs-ec interface to Sony sensor
I have implemented an 8 lane slvs-ec interface to the IMX420 sensor. I have it functioning but I randomly run into an issue on startup (bringing the sensor out of Standby where it starts sending the ...
Jens
2 years agoDear mmeyers,
did you have any experiences with the PRBS test pattern from sensor described in SLVS-EC Spec., Annex H?
I'm using Arria 10, Native Phy and similar settings like you. The rx_is_lockedtodata and rx_syncstatus signals are high but the SLVS-EC Phy codes are not correct or not comlete. So I will check the connection using the sensors test pattern. Therefore I need the 511 bytes between the K.28.5 symbols.
Jens
