mmeyers
5 years agoslvs-ec interface to Sony sensor
I have implemented an 8 lane slvs-ec interface to the IMX420 sensor. I have it functioning but I randomly run into an issue on startup (bringing the sensor out of Standby where it starts sending the ...
CheepinC_altera
5 years agoHi,
Thanks for your update. Regarding your latest inquiry on the IO standard to use, sorry as I am not familiar with SLVS-EC and could not comment what is the required IO standard for this protocol.
However, if you are using the AV GX transceiver receiver, the supported IO standards are 1 .5 V PCML, 2.5 V PCML, LVPECL, and LVDS. When configured in either of these IO standard, the receiver support the same set of specifications as in AV device datasheet -> "Receiver Specifications for Arria V GX and SX Devices" table.
You may refer to the table and cross check with the interface requirement or specs of SLVS-EC to ensure compatibility.
