slvs-ec interface to Sony sensor
One of the possible cause to the 8b10b error at AV RX is related to the signal integrity. Just wonder if you have had a chance to measure the eye diagram at the AV RX with oscilloscope and check against the datasheet to see if there is any anomaly or violation of the specs.
- mmeyers5 years ago
Measuring eye diagrams is pretty difficult for us. The data rate is 2376 Mb and the board is very dense. What I can say is that when the link does come up, we can run a test pattern from the sensor into the fpga and do a pixel - pixel comparison to a known good reference. Test runs overnight with zero errors so we're pretty confident signal integrity is not the issue.
I had left out one piece of info in original post. Due to the Arria5's maximum fabric rate, I couldn't run the recovered byte info into logic to perform the final byte unpacking as defined by SLVS-EC spec. I had to use the transceiver's ability to go double wide on output (at half the input rate). Using SignalTap, on good startups, I see the 8B10B error signals bouncing around until I bitslip the incoming bytes to get byte alignment. At that point the 8B10B errors stop and system is happy which I would expect. On bad startups, I see the 8B10B errors continue on. I'm convinced the issue lies in the single to double wide conversion somehow.
CheePin_C_Intel, if you have any thoughts on this, would appreciate hearing them.
