15 years agoSLOW Flash write and erase
Using the HAL function alt_write_flash(..) it takes appr. 2100 mSec to write one block of 131072 bytes to a Numonyx 1 Gbit flash with 1024 blocks. I am writing to block 1007. Same problem with al...
15 years agoI think these are usual erase/programming times for a common NOR flash.
What flash device are you using? I have here the datasheet for a Numonyx Strataflash memory and it specifies values similar to yours.
