15 years agoSimulating a VHDL array
Modelsim-Altera returns an error when I try to drive the 'x' inputs in the code below: "Error: (vsim-3455) Can force arrays only if they are one-dimensional arrays of character enums." ...
15 years agoOkay, thanks for the help. I changed the code to:
library ieee; use ieee.std_logic_1164.all; package pkg_array is type vec_array is array(integer range <>) of std_logic_vector(7 downto 0); end pkg_array; library ieee; use ieee.std_logic_1164.all; use work.pkg_array.all; entity gen_mux is generic (n: integer := 2); -- Set the number of 8 bit inputs (2**n) port( x: in vec_array(0 to (2**n - 1)); sel: in integer range 0 to (2**n - 1); y: out std_logic_vector(7 downto 0)); end gen_mux; architecture description of gen_mux is begin y <= x(sel); end description; Here's the tcl command I used to drive the x inputs, with the resultant error: force -freeze sim:/gen_mux/x {{{00000001} {00000111} {10101010} {11110000}}} 0# ** Error: (vsim-3455) Can force arrays only if they are one-dimensional arrays of character enums. Is there a way to change this code so that Modelsim-Altera will allow me to drive the inputs? Thanks, Steve
