emma97
4 years agoSimple MAX 10 project with DDR3 UniPHY using HDL only
I want to implement a simple hdl design for the Arrow DECA. Most examples make use of other IP's like the Nios II Processor to control the DDR3 SDRAM. But I want to build my IP Variation and control ...
AdzimZM_Altera
4 years agoHi Emma97,
I'm Adzim. Thank you for using Intel Community.
Did the design passed calibration?
If yes, then I think you should use a larger burst size such as 32 or 64.
You can refer to the Table 96. Local Interface Signals on "External Memory Interface Handbook Volume 3". I think the signals have been explained there.
The avl_burstbegin indicates when the burst operation will start.
You may read this document for better understanding: https://www.intel.com/content/www/us/en/docs/programmable/683091/20-1/burst-transfers.html
Adzim
