18 years agoSilicon Speed
Hi, I have a basic query regarding FPGA's in general. I always believed that silicon is faster at lower temperatures and slower at hotter temperatures, but that the core current in an FPGA is...
18 years agoThanks again anakha
I think I have things clear now, but just one more thing.. I was reading in a handbook a while back that in the classic timing analyzer, if I place a maximum or minimum delay constraint for an output pin, but only specify one, then quartus will attempt to match this exact time. For example if I place a constraint of maximum delay 2 ns (without specifying a minimum delay), I understand that quartus will attempt to assign the ouput in 2 ns exactly. But if the temperture swings then this may not be possible? So does quartus attempt to assign the output in 2 ns for typical corner only meaning that at the fast and slow corners the designer would have to expect a slight error? Would it always be advisable to specify a maximum and minumum delay in this situation, to ensure than the contraint can be meet at all corners? Thanks again.
