SDe_J
7 years agoSignaltap problem with Stratix 10 Production Kit
I have created a very simple project in Quartus 18.0 for a stratix 10 development kit. The project uses a 100MHz clock to drive a counter, which counts from 0 to 99. I have added a signaltap instance...
SreekumarR_G_Intel
7 years agoAre you using Startix 10 GX L tile Development kit ? If your design is not confidential, Can you attach in the forum so i can have a look ?
I really dont think so there is link for signal tap analyser not working because of not including or including the timing constraint.
Thank you ,
Sree
- SDe_J7 years ago
Hi Sree,
You are correct, I am using the Stratix 10 GX L-tile dev kit. Attached is a qar file containing my project. I am currently using Quartus 18.0.
If you are able to take a look and see if you spot anything obvious, that would be great.
-Sam
