EEren
6 years agoSignalTap problem.
FPGA (MAX10) connected to a microcontroller board. If I disconnect the board SignalTap runs good. If I connect the board back - SignalTap starts and immediately writes - Invalid JTAG configuration. ...
EEren
6 years agoThe problem was CFG_DONE pin. It was connected to CPU pin configured as output. I don't know why but this pin affects Signal Tap flow.
ShafiqY_Intel
6 years agoHi EEren,
Have you able to solve this CFG_DONE pin issue?
Any solution you can share to community here?
- EEren6 years ago
I just configured this pin as input on the CPU side.
