15 years agosignaltap: Can't find the instance
Hi, I have a problem about using signaltap, when I press Run analysis,there have an Error: Can't find the instance. Download a design with SRAM Object File containing this instance. What dose th...
15 years ago --- Quote Start --- But when I download the *.sof file, then capture the data, there have no error. Why? --- Quote End --- I guess, it's a different design.*.jic has to be generated manually, unless you have written scripts that make it after compilation.
