15 years agosignaltap: Can't find the instance
Hi, I have a problem about using signaltap, when I press Run analysis,there have an Error: Can't find the instance. Download a design with SRAM Object File containing this instance. What dose th...
15 years agoIt means, that you have to enable the SignalTyp II instance before compiling the design. The error can also indicate, that you haven't downloaded the recent FPGA image.
