8 years agoSignalTap & Keep Attribute - how to prepare signals for SignalTap during RTL coding?
Hi All, I'm using the keep attribute in order to prevent from the Quartus Synthesizer to optimize (rename/delete/etc) the signals, which have such attribute. So, is it possible to select ...
GZwei
6 years agoUnfortunately, this is not entirely true as it seems. Nodes that get removed in synthesis cannot be selected in SignalTap using pre-synthesis. The signals are visible when using the option "Design Entry (all names)", but attaching SignalTap to registers that get optimized away is not possible. Neither the syn_keep attribute and the preserve attributes work. The only way to get SignalTap to attach to these registers is to combine them with a dummy logic function that is never true, and then or it to some other signal that is used. :-(
