15 years agoSignal tap removal
Hi all
I have an easy question. I compiled my design and then I appen signal tap analizer. It append to my design a new entity, "sld_signaltap:auto_signaltap_0". I run my design, made my analysis and now I would like to remove the entity. Well, I removet auto_signaltap_0.stp from my design, but the entity is still there. Any hint would be appreciated. Best regards Phate P.S. I use quartus2 10.1 web edition, so no incremental compilation or similar.3 Replies
And if that doesn't solve it, delete your /db and /incremental_db directories and try again.
Quartus includes instance information for signaltap in your QSF. The best way to remove this from your design and QSF is to:
[1] remove the enable signaltap setting under the project settings [2] run analysis & elaboration
