13 years agoSignal tap II issue
Please check the attached image, why some signals are fuzzy? They supposed should be clean "low" or "high" Many Thanks. https://www.alteraforum.com/forum/attachment.php?attachmentid=6...
13 years agoSignalTap is based on digital logic, so it either captures a 1 or a 0. (It could go metastable, but that won't show up in the SignalTap waveform. And since captured data just feeds a large capture buffer, it's unlikely to cause any problems at all, since the fanout is probably 1 the whole way...)
The numbering on the top is your clock edge. Your sampling with a clock that is much faster than most of the signals, but when they transition a lot, it looks like that. Zoom in and you should see clean values for each clock. (Looks like you have a pretty deep buffer size...)
