17 years agosignal tap console output
Dear All, i'd like to use signal tap analyser to grab the internal data from the FPGA and use them for further processing (2ksamples of 14bit adc data to produce average, standard deviation and FF...
17 years agoWow. Definately did not read your whole post, just the first part. Had i read your whole post probably wouldn't have responded cause i just told you what you already knew. Besides using the export inside the stp console, which would give you a csv file or any other format you want, i don't know how to do it without using the gui. Sorry.
kevin
