15 years agoSignal Processing
Hi guys, First of all I would like to thanks everybody for the tips. But now I have another problem. I am building a receiver and I will use FPGA to process the signal. My receiver has a f...
15 years ago --- Quote Start --- Hello Dave, Thanks for all, I would like a reference on digital signal processing, because I didn't understand very well what you said. thanks --- Quote End --- I would recommend getting a copy of Understanding Digital Signal Processing, 3rd Ed, R. G Lyons. Also read this document. There are plenty of references at the end of it as well. http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-320paper_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-320paper_hawkins.pdf) In these slides, you will see power spectra calculated from radio galaxies http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-320slides_hawkins.pdf (http://www.ovro.caltech.edu/%7edwh/correlator/pdf/esc-320slides_hawkins.pdf) Cheers, Dave
