15 years agoSignal Processing
Hi guys, First of all I would like to thanks everybody for the tips. But now I have another problem. I am building a receiver and I will use FPGA to process the signal. My receiver has a f...
15 years ago --- Quote Start --- Hi Dave, thanks for all. My problem is: I have a frequency range 100 KHz to 3 GHz and I have to detect all signals between that frequency range, for example (AM, FM, GSM, Bluetooh...etc). I need to choice a ADC and implement the signal processing in FPGA. I don't know which ADC I can use. The maximum bandwith that I have to try to sample is 20 MHz, But I don't know how many bits my ADC must have. --- Quote End --- You still have not specified what you want to do with the signals. By 'detect' do you mean demodulate, or just 'detect' power? The number of bits required from your ADC will depend on what type of signal processing you want to perform. However, a 16-bit 100MHz ADC will likely do anything you want. There are Altera HSMC cards with that feature (Terasic), and some of the Altera DSP kits have 100MHz ADCs. Are you planning on buying a commercial demodulator? Building a demodulator that takes 3GHz down to DC is a non-trivial task. You will likely need different types of analog front-ends, and switch between them, eg. op-amp based designs from DC to ~100MHz, and RF amplifiers above that. Of course, you could sample the signal directly, but you would need an ADC with an analog input bandwidth of over 3GHz. National Semiconductor and e2v have GHz clock rate parts, eg. http://www.e2v.com/products-and-services/hi-rel-semiconductor-solutions/broadband-data-converters/datasheets/ You might be able to find a manufacturer with one of these ADCs on an Altera board, eg. Bittware http://www.bittware.com/products/hardware/prod_desc.cfm?prodshrtname=3fad-s43x Depends whether you're looking to build or buy really. Cheers, Dave
