13 years agoShow gray image on vga
hi
ı have de2 115 board and d5m camera ı want to show gray image on vga screen. Vga has 3 signal pins red green and blue but gray only one value ? How ı can show gray image ? thanks for answers2 Replies
I don't know your [particular hardware but, speaking as a digital photographer, my understanding is that setting RGB to the same value will produce a neutral colour (assuming calibrated display hardware), somewhere between black and white inclusive.
Whether the colour is grey or not depends on the overall intensity. By convention, setting R=G=B=<minimum value> should typically result in black, R=G=B=<maximum value> should typically result in white. - Altera_Forum
set RGB all to the same value
