15 years agoSharing PLL - using SOPC Builder
Hello folks, I have instantiated 3 DDR3 Memory controllers into the Nios II CPU and each memory controller uses its own PLL (3 PLL's used). As all the memory controllers operate on the same clo...
15 years agoHi I found the solution, it's in this file http://www.altera.co.jp/literature/hb/external-memory/emi_tut_qdr.pdf
you have juste to follow the instractions and it works ... good luck
