15 years agoSharing PLL - using SOPC Builder
Hello folks, I have instantiated 3 DDR3 Memory controllers into the Nios II CPU and each memory controller uses its own PLL (3 PLL's used). As all the memory controllers operate on the same clo...
15 years agohi, did you find a solution for your probleme? I have the same...
Thank you
